sma2bim
Wall Display intersection
 The priority are good ,
but the lines of wall core continue to the outside of the other wall.
[ BIM Manager- Revit Expert
Win 11 - Dell Precsion i7 | 32GB | RTX A4000
AC25 - AC26 4019 Int Full]
13 Replies 13
sma2bim
indeed 1,2 & 5 🙂
Actually the two wall are interior so two plaster types will be a mess to manage in the quantities (another software).
Hope graphisoft will work in this little issues (coz there many)
I manage this problem like this:
# If the two walls 3&4 have the same BM, I'd only duplicate the BM with different (name & cut fill) while keeping priority and all settings the same.
# If the two walls 3&4 have different BM I'd only check that they've the same priority as they already have different cut fills.
Then I split the vertical wall 3 exactly at the reference line of the horizontal wall.
 so that's the result.
AC 29 INT 4006/WIN 11
sma2bim
Thank you ,
actually this solution works .
I'm happy it worked, thank you.
