GBennett13
Wall Extras Randomly Disappear
Has anyone got a fix to the Wall Extras - Dentil Courses / Dentil Verges randomly disappearing once placed in 3D? It is really strange, they are visible on plan, and when selected and 'select in 3D' is selected, still nothing. Happening in both AC29 & AC30.
2 Replies 2
Lingwisyer
Guru
So it is less that they disappear, but that they do not show in 3D? Which Wall Extra? If it is extruding Complex Profiles, it could be generating invalid geometry which would cause it to fail generating.
Ling.
You had a post label for 'Design Options' which I removed because you post does not mention anything about design options.
But that has made me think.
Are you placing the accessory object in a design option that is not showing in the 3D view or with a renovation filter status that is not showing in the 3D view?
It shouldn't be that the layer is hidden if you are using 'Select in 3D'.
Sometimes the accessories can be difficult to select in plan.
Try a marquee and see if it shows then.
Or don't select anything and 'show all in 3D'.
