Wall Intersection priorities & blade wall return
Hi All,
Please see attached sketch.
I'm struggling to get the wall priorities to work for this intersection - any ideas about how to achieve my desired outcome?
I've used 3 composite walls. Should I consider drawing the blade wall with single skins of face brick to achieve the return on the blade wall?
Thank you kindly
Dontknow
Yes, I think that's your only solution.
Draw in single pieces of walls.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thanks Dontknow...that makes sense, a good work around that avoids patches
DGSketcher
Legend
I haven't tried it but you could consider a column with a complex profile to form the blade and connections. Just a thought.
