‎2008-03-19
04:58 PM
‎2023-05-25
05:53 PM
Rubia Torres
‎2008-03-24 03:13 AM
‎2008-03-24 09:19 AM
‎2008-03-24 12:01 PM
kliment wrote:Sorry Kliment. I really didn't read carefully your post...
This is the best result I have achieved so far:
- Single-story walls.So we get back to AC9 modelling!
- Bottom wall with Composite Fill.
- Top Wall with Complex Profile. Origin is below the Story Level.So we have to set the wall to show to "Home Story Only", otherwise we get dashed contours . This also makes it impossible to use multi-story walls!
- Slab has to be manually sent to back.
- When we save as DWG we have to manually clean the intersection as all the lines, hidden by the fills, will appear on the drawing.So I usually do a lot of clearing in Autocad afterwards!
For proper representation we have to SEO the wall with the Slab.This is an extra operation we have to perform for each wall and slab on every story. I just do not have enough time for this!
‎2008-03-24 03:05 PM
Braza wrote:Oh, it doesn't work at all! I still haven't found a proper way to make it work!
But if it works for you that's ok too...
‎2008-03-24 04:46 PM
‎2008-03-24 05:58 PM
DavidShorter wrote:David,
Now I need to know how you actually build this. Is the wall concrete like the slab or some other material.
Is it built in one go or is one pre cast the other insitu?
Do the slab lines (or do you want to) show in elevation
It really interesting as we would never take the slab out the the outer face of the wall these days... what circumstances would you use this detail?
Sounds like I'm playing for time
‎2008-03-26 09:07 AM
‎2008-03-26 11:29 AM
‎2008-03-26 05:40 PM
‎2008-03-26 05:53 PM
