We value your input!
Wall angled to rise along its length
Is there any way to have a wall angled so that one end is higher than the other?
The only way I can do it to create a beam profile. This is ok as long as I do not want a curved wall, which I do .
Any pointers will be appreciated.
TIA
11 REPLIES 11
Dwight
curved ramp object should do it.
Dwight Atkinson
Hi Dwight, could you Please explain how do I use the curved ramp object as a wall? As a matter of fact I want to drop this wall on a curved ramp .
Dwight
Make it narrow and tall.
Dwight Atkinson
Dwight
DO you need openings in this wall? If so, it is more complex:
you'll use ramps to SEO away the top and bottom of any curved wall.
Dwight Atkinson
Will give it a try. Yes I do need windows (actually, the middle part of the wall is all glass as shown in the picture above).
Thanks a lot Dwight; appreciate your time. Regards.
NCornia
Graphisoft Alumni
Graphisoft Alumni
I noticed in your signature that you have AC16 and this is a perfect chance to use the new Morph tool. I made a quick video you can reference: http://www.youtube.com/watch?v=Qq1QnCI2xyQ I used a simple wall but you could create a complex profile that includes the glass as you show in your picture, then convert to a morph.
I did not include it in my video but you can classify a Morph element using the Element Classification in the Morph Settings dialog under Tags & Categories. This way you have some ability to schedule the wall and perform quantity take-offs.
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Wow! Nicholas. I am now beginning to understand the features of the morph tool.
Thanks very much and this has solved my issue spot on.
The video is very helpful.
Regards
S
Stress Co_
Fine job Nicholas. Your videos are informative, concise and easy to watch.
Thanks
Marc Corney, Architect
Red Canoe Architecture, P. A.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Thanks
Thank you.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
