2023-08-25 09:22 AM
I am trying to generate a overwrite rules for wall setout plan. I successfully setting a criteria so it highlights the wall in different color according to the material. But I realize that ArchiCAD pick up the wall as a whole, and not the specific material.
For example, a typical double brick wall:
110mm brick
50mm cavity
110mm brick
10mm plasterboard
ArchiCAD will shade the entire wall, BUT instead, I want it to highlight the two 110mm brick ONLY. Is this possible??
2023-08-25 09:31 AM
No.
Graphic Overrides affect the entire element.
2023-08-25 11:32 AM
If your drawing is black and white, you could have a Pen Set in which the pen for your relevant material is coloured. Might that be enough?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-08-28 01:00 AM
Let me try! Thank you for the suggestion.
