dongdong
Wall composite
I am trying to generate a overwrite rules for wall setout plan. I successfully setting a criteria so it highlights the wall in different color according to the material. But I realize that ArchiCAD pick up the wall as a whole, and not the specific material.
For example, a typical double brick wall:
110mm brick
50mm cavity
110mm brick
10mm plasterboard
ArchiCAD will shade the entire wall, BUT instead, I want it to highlight the two 110mm brick ONLY. Is this possible??
3 Replies 3
No.
Graphic Overrides affect the entire element.
Guru
If your drawing is black and white, you could have a Pen Set in which the pen for your relevant material is coloured. Might that be enough?
dongdong
Let me try! Thank you for the suggestion.
