When I've experienced these types of issues, I've found the culprit can be a complex profile involving itself unexpectedly in the results. It appears you may be using one in the footing below? In such cases, I've substituted simpler components to resolve it. For example, if a complex footing is the issue, I'll use a slab/beam and wall solution instead.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sequoia OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
