Wall connection material problem.
I have problem about wall corner material in Archicad 18. Two wall has same junction order value : 8
I have never get a problem like this in Archicad 16[/img]
3 Replies 3
Wall seems like this in Archicad 16
James B
In the Wall settings, Model tab, check the "End Surfaces: Override using Adjoining Walls" for the Wall with the brown edge surface. This checkbox is also available from the info box surface popup of Walls.
James Badcock
Eduardo Rolon
Change this setting for the wall that is giving problems.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
