Wall corner not cleaning up properly
I am a new Archicad user (migrating from Revit) am discovering all the quirks that don't show up until you have to do some real work. The wall intersection in a T formation cleans up nicely. The exact same walls where the interior wall meets a corner don't clean up properly. The priorities are correct. I have tried all manner of placing the walls but nothing works. Any suggestions?
KrisM
insideru
Whenever it comes to intersections it's usually the priorities. Also make sure that your walls' ref lines are properly connected.
ARCHICAD 28 INT
macOS Sequoia
Okay, thanks. I got it to work but had to play around with the drawing order to get it to cleanup. Quite a bit more fussy than Revit but I know Archicad excels at other things.
