Hi
I understand you have a Wall and have created an opening by using Connect /Solid Element Operations.
Here is the glitch: solid Element Operations applied on walls will not be reflected on Plan views... so you're not doing anything wrong.
My alternative for your specific intention:
split the wall in two and use the Wall End tool and choose the chamfer one.
see pic.
Alternatively, y
ou can use the Shell tool instead of the Wall Tool, with it you can create custom holes in the shell that will show correctly in floor plans.
Nando Mogollon
Director @ BuilDigital
[email protected]Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
