jmk:
Wall display on multiple stories is different than Objects. You need to use the Wall Settings > Floor Plan and Section > Show on Stories >
All Relevant Stories, then use the
Floor Plan Cut Plane (which is a View setting) to control the display of the Wall. You will want to read about the Floor Plan Cut Plane settings to get a handle on this.
David
