Mike96
Wall edge surfaces are not overridden
I have a problem with a specific model from which I extracted two walls, built with the same material, on the same layer and storey, with base lines connected, but:
The side (edge) surface finish of the thicker wall doesn't get overridden, and you can see default material texture showing through, even though all wall surface finishes are overridden in the settings, for both walls.
The problem does not occur with a fresh model - only in this one.
I can't figure out what's wrong with these walls. Can you help?
Please use the attached PLN, saved in AC 25 POL.
ArchiCAD 25
Windows 10
10 Replies 10
Mike96
I wasn't even aware of the legacy settings in Archicad. It indeed fixed the problem.
Thank you all for the input!
ArchiCAD 25
Windows 10
