Wall end lines
Working on AC 18 the wall end lines , regardless of type of request (left, right, both etc) keeps the end of the wall unchanged.
Just a minor annoyance but I am wondering if other experience the same
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
6 REPLIES 6
David Maudlin
Conrado:
Works here. Could the walls be intersecting another wall on a hidden layer?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Greetings, David
It works with a generic wall, it does not work with a free ending of a composite wall.
A 2x4 with 5/8 gwb composite wall, when placed in 2D, does not show the gwb "wrapping" around the free end; in 3D shows the 2x4 wood core.
The wall end lines option does not wrap skins around the end of the wall - it simply turns a line on or off at the end.
To wrap skins you need to use the 'Wall End' tool.
Thanks Barry
I forgot the Walls end tool
Michael Grant
Similar issue, old thread.
I don't know how to change the wall end lines...!
In Wall Selection Settings > Wall End Lines, the line appears randomly as a thick red line.
  • My wall is a Profile Wall (not a Composite, where you can set the wall end line pen)
  • I would prefer to use the the Wall End Tool to wrap the skin, but Wall End Tool won't recognize a Profile wall, based on my experiments
  • So now I just want to change the red end-line pen to black
Any help please?
____________________________
Running AC25 on Mac OS 12.2.1
(Psst not a newbie, just lost my old user profile...)
When you select a fill in the profile editor, you can control the cut end line.
