Wall fills wont connect nicely?!
JelenaKujundzic
how do i connect walls with different fills as shown in the picture? the wall with one fill just automatically extends till the end of the other one and so does the fill, and therefore cuts the first fill?? Why doesnt it stop on the connecting point of the two?
Thank you
Ernest Atanasiu
Walls will automatically trim to their reference lines when they touch.
You can manually trim them so they stop where you want, but the building material strength will solve your problem.
Stronger building materials will cut the weaker ones.
