2010-01-04 10:41 PM
2010-01-04 11:00 PM
2010-01-05 04:39 AM
Michael wrote:Or solid element operation.
...use the Trim to Roof command.
2010-01-05 12:32 PM
2010-01-05 02:21 PM
2010-01-05 05:34 PM
laszlonagy wrote:As I recall the trim to roof does shorten walls and move slab edges. This is because it is making a permanent rather than contingent alteration. But it is not necessarily a true representation of the result in plan - ie the wall end will be perpendicular even if the trim cut is not.
The cut made in 3D will not be reflected in the 2D representation of the Wall, whether you use Trim to Roof or Solid Element Operations. This part works with neither.
2010-01-05 07:08 PM
Matthew wrote:Yes, Matthew, you are right, there are some cases when Trim to Roof may cause the desired result in 2D as well.
Thanks for the clarifications Laszlo, and for all your work as moderator. You are proving a worthy successor to the esteemed Djordje.
2010-01-06 11:12 PM
2010-01-07 02:57 AM
2010-01-07 03:37 AM
Jeff wrote:Here's a video recently uploaded to YouTube:
Could someone please direct me towards a tutorial on solid element operation.
