Wall (inside/outside)
Eman
Let's say I draw a square with the line tool, then I draw the wall from left to right. How can I change the wall to be drawn inside the square instead of outside?
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
DGSketcher
Legend
You may find this link to the Wall Tool settings and the rest of the site helpful while you are learning AC.
https://helpcenter.graphisoft.com/user-guide/77533/
DGSketcher
Legend
Eman
Thanks DGSketcher
Eman / Draftsman
