Depending on the direction your walls trim you ma need to plaster to be stronger than the timber studs.
It is all a bit of a juggling act.
Decide what needs to always connect and make those stronger.
i.e. the internal and external claddings and the cavity.
Sometime you have to duplicate a BM so you can have one strong and one weak.
i.e. external cladding strong and internal cladding weak - even though it may be exactly the same cladding.
And another tip is not to use minimum or maximum strength as it leaves you nowhere to go if you need weaker or stronger BMs.
You will never be right 100% of the time so you may find yourself duplicating BMs and composites as well just so you can tweak them in special cases.
