Wall plinth in door openings
Sandramuller
I created walls with projecting plinth with the complex profile. Great but I can't get the plinth to wrap around at the door openings. Graphisoft  helpline advised to add a separate object  button the plinth  object just disappears in the door openings.
Surely I can't be the first one having walls with plinths?
Anyone  managed it?
1 REPLY 1
DGSketcher
Legend
If you have created a separate plinth element, put it on a different layer with a unique Layer Intersection value so that the wall/door doesn't remove it. You may end up with some unwanted lines if you are joining up with the complex profile wall. I model such wall features independent of the main wall so they can also be turned off in the general plans.
