2007-12-03 10:08 PM
2007-12-03 10:31 PM
2007-12-03 10:39 PM
2007-12-04 01:27 AM
Thomas wrote:You could also make the lower wall three sections, with the middle section the same length as the upper wall, if you don't want to have double storey walls.
The workaround is to make the middle part one wall with double height instead of two stacked. This wasn't really possible until AC10.
2007-12-04 07:36 AM
2007-12-04 08:58 AM
2007-12-04 11:51 AM
Mats_Knutsson wrote:But that defeats the whole BIM philosophy.
Thanks all for your replies!
Parts of this actual project have walls that are multi-story high but then there are several situations where this method can't be used.
I'm OK with exploding the elevations as a work-around.
Mats
2007-12-04 12:02 PM
laszlonagy wrote:Yep!Mats_Knutsson wrote:But that defeats the whole BIM philosophy.
Mats
