Wall roof intersection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-06-21
02:06 AM
2023-05-19
10:34 PM
Gordana Radonic
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
Solved! Go to Solution.
- Labels:
Connections
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-21 03:10 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-21 03:10 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-21 06:04 PM
Kris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-22 12:03 AM
Barry wrote:Thanks for the info. I tried Junction Order in Wall Settings with no luck, but Intersection Priority In Building Materials did the trick. I would never have never have found it without your instruction. Thanks again.
Either use a building material in the roof that is stronger than the building material in the wall or do a Solid Element Operation instead of connect/trim to roof.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-22 02:47 AM
KrisM wrote:If the SEO worked on a morph it would have worked on a roof as well regardless of building material strength.
I had the same problem the other day. Tried all the suggestions but none worked. What did work was to convert the roofs to morphs and then use solid element operations.
Kris
The 'Connect > Trim to roof/shell' works too, so long as the strengths of your building materials are correct.
Strongest will cut the weakest.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-22 06:33 PM
Yes, you are correct. I think I got mixed up on which material I was making stronger. One was called "Generic Building material" and the other "Generic Exterior Material". Glad to see it works as intended.
Kris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-02 11:19 AM
Thank you for the explanation, Barry! Your image attachments are always so easy to comprehend.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-11-29 11:11 AM
Thanks for the help,
I had the same problem so I copied the material of the wall, made it a little bit stronger and used it for the roof. In 3D working great, but now in section I don't visualiza anymore the wall and the roof like the same material (ovviusly).
I can I solve that?
Thanks!
