‎2007-05-18
07:24 PM
‎2023-05-25
05:13 PM
Rubia Torres
‎2007-05-18 08:49 PM
‎2007-05-18 08:58 PM
‎2007-05-18 09:21 PM
TomWaltz wrote:
Not directly.
You could do a Solid Element Operation to cut the walls off below the mesh.
‎2007-05-18 09:25 PM
‎2007-05-18 09:37 PM
‎2007-05-18 09:52 PM
Peter wrote:You are right I did not follow the steps correctly.
Why is the solution I proposed "a handful of time" ?
I just did it on a mesh with 32 contours and 30 walls in about five minutes.
Peter Devlin
‎2007-05-18 10:35 PM
Djordje wrote:
ArchiTerra has walls following the terrain.
‎2007-05-18 11:00 PM
but as of last year decided if I can do with out Add-Ons by using AC tools with some work arounds or innovative methods I should do so. Add-Ons at time of a upgrade are usually a problem with delays in availability or bug.agree 100%..the only one i consider a must is archiforma
