Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wall top height link
When I change the top height of a wall to Not Linked with a custom height, its not possible to relink it to a story level again, is there any solution that i'm not aware of?
10 REPLIES 10
Podolsky
Ace
Sabzbon wrote:
When I change the top height of a wall to Not Link with a custom height, its not possible to relink it to a story level again, is there any solution that i'm not aware of?
I think you can relink to storey top of the wall.
Guru
Same button you clicked to unlink...
Thanks for the reply, yes I know that but for me when I select a story, it jumps back to unlink again, maybe my archicad has a bug? I tried this on Archicad 25 and 23, same situation on both
Is this wall part of a hotlinked model?
No it's not
I see...
Perhaps some screen shots of your wall and story settings would put some light on it.
I tested that in default template and same happend but I found the problem, if you change the height, befor you do the relink you have to manually set the story height then link the wall. if the height is anything other than story height, it wont relink
Guru
AC25 bug? No issue in 22 or 23.
Tried on both with their default templates
same happened, wierd!
