Walls Not Joining Correctly
I've got my walls on the same layer, same priority number, and same type.
When some of them join there is there weird white space in them. Ive tried redrawing the walls but the blank space still won't go away. Anybody have some suggestions?
2 Replies 2
Some questions for you.
What version of Archicad are you using?
Where are the wall reference lines?
Are the walls all the same top and base heights?
Are there any other walls in other hidden layers?
Have you tried selecting both of the cavity walls and then using the 'Intersect' tool to join the corner?
What happens if you stretch the end of the single leaf internal wall away from the cavity walls - do the cavity wall then join correctly?
If so then stretch it back and see what happens.
Barry
gpowless
"When some of them join there is there weird white space in them."
I have found this occurs when the walls below are joined in line with the walls above and 'All Relevent Stories' is selected in the view. A work around is to create an offset of the walls below by 1/32" to change the alignment.
Intel [email protected] 16g
