Walls cut Beams and Columns
fowebe
Hello! I'm trying to make an Isometric view of my Structurals but it seems that the walls cut off parts from the columns and beams. (The walls layer is just hidden.) How do I show the whole column/beam without deleting anything?
Thank you very much!
Phoebe
_________________
Phoebe Lim / Architect
AC26 • Windows 11
David Maudlin
fowebe:
For the Isometric View, create a new Layer Combination where the Wall layer has a different Intersection Group Number than the Beams and Columns layers. In the Help files see: Home > Configuration > Attributes > Layers > Use Layers to Prevent Intersections.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
fowebe
Thank you so much, David Maudlin!!!
Will take note of that, thank you!
Phoebe
_________________
AC26 • Windows 11
