Walls hight in section
Hi!
I missed something or is a bug?
I can not stretch the wall in section,with Arch19 I was be able to to in 18.
Thanks for any suggestion
19 Replies 19
Getting the same issues with the AUS version when wall is placed at AHD level( basically at 0 ). But weirdly, if I delete the default sections and recreate new sections, it all works....???
David Shorter
It seems to be a problem when there are thin skins on the face of the wall. The selection picks the wrong hotspot .... choose a face which has no thin skin like the face which is the brick skin and it will work properly. Alternatively zooming in to make sure the you select the hotspot not the other skin line and it will work properly.
Yes a very irritating bug
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Yes, seems to be related to the zoom..although if you select the wall zoomed in, it stretches, zoom out with the wall still selected and no stretch available???
Wow ok I came across this before yesterday
It is not a bug as such, Just very annoying
it is just that Graphisoft have changed the default wall height option to the new option (which they shouldnt but they keep doing with new features)
In your wall selection setting change the 'Wall Top' dropdown from which ever selected floor to "Not linked"
this stops wall being automatically set to the floor to floor height by default
David Shorter
it still happens when not linked if you are using a composite or complex wall
A single skin wall works fine.... linking (or not) doesn't affect the operation
Mac Studio
iPad Pro
iPhone
Jeff Kogut
This bug is KILLING PRODUCTIVITY.
That is all.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
Jeff Kogut
This is still my A-number-1 daily most frustrating part of using 19. Please address ASAP.
Katalin Borszeki
Hi, we do have our fingers on this bug already. It appears at wall joints on sections and elevations.
If the black dot of the end of the wall and the reference line of the wall are overlapping, ARCHICAD is unsure about the selection and this causes the problem. Our developers are planning to fix this shortly in an upcoming update! Thanks,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Eduardo Rolon
Jared told me a possible workaround which is to select a text or another object in addition to the wall then it is possible to stretch them.
Have not tried it yet.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Hello !
Have you find a solution for this problem ? I have the same with archicad 19 on windows 7, but not with my archicad on my apple... very weerd...
Thx a lot !
