‎2004-05-14
12:32 PM
‎2023-05-23
03:42 PM
Rubia Torres
‎2004-05-14 02:22 PM
‎2004-05-14 02:56 PM
‎2004-05-14 03:12 PM
‎2004-05-14 07:12 PM
Vincent wrote:It is a wish ... but the object-making workaround isn't so bad unless you do these kinds of walls in all of your designs. Draw your wall including all windows with the wall tool along the X axis (for example). Save it as a module so you have the original parts available for future editing and re-saving. Save the wall as a GDL object. Add a ROTX command into the script using a fresh angle parameter and you can then rotate the wall/window assembly as needed. All of this takes less than a minute once you're used to it. (The most time-consuming part would be editing the 2D symbol to reflect how you want the wall to appear in plan.) If the canted wall needs to be trimmed with other walls, use solid element ops.
The placed window only generates a hole in the placed object; also I just want to place frames in tilted walls.I'm very glad that you took time answering my question but am I missing something or is my question actually a plain wish for GS?
‎2004-05-14 08:00 PM
Vincent wrote:If this is the only problem, try ArchiWall by Cigraph.
but this tool actually just places an an object in front of the wall; I don't want the original wall stil be there. I want a tilted wall. When I throw away the vertical original wall I throw away also the angled object.
Vincent wrote:I suppose the frames have to follow the tilt of the wall, right?
Second, The placed window only generates a hole in the placed object; also I just want to place frames in tilted walls.
Vincent wrote:No wish from a user is or should be "plain". Take alook at the wishlist forum - if no tilted walls are there, please do post your wish, or reinforce the case for the existing one!
‎2004-05-14 10:17 PM
‎2004-05-14 11:12 PM
Peter wrote:Thanks, Peter.
Karl Ottenstein wrote:
"Add a ROTX command into the script using a fresh angle parameter and you can then rotate the wall/window assembly as needed."
Would it not work better to use XFORM rather than ROTX as this transformation would shear both the wall and the window?
I am not sure about this but Karl would know.
I believe he was the one who wrote that excellent library part
that explained and demonstrated XFORM.
Just wondering,
Peter Devlin
‎2004-05-14 11:26 PM
‎2004-05-14 11:57 PM
