We value your input!
Walls losing fill, windows and doors Archicad 13
I have been working on a drawing for some time when all walls started being displayed as parallel lines but kept their widths and properties. The window and doors disappeared at the same time. Although I'm able to add new ones, I can't see them.
Is it simply a case of changing a display property? If I copy and paste into another file everything reappears but I don't want to do that if I just have to click one display option that I haven’t found yet.
Dwight
You may have accidentally altered the model view options, but also:
Check your floor plan cut plane setting [Under DOCUMENT] to be sure that it includes a range of heights that include the windows and doors from the current storey.
Dwight Atkinson
Great Thanks,
I was working with Ceiling Plan settings
Document -> Set Model View -> 04 Ceiling Plans
I resist to 03 - Building Plans to return all missing detail.
Best wishes
C
