Walls not joining
Hi! I created these walls with the magic tool out of a morph. The morph consists of seperate lines that are connected but are segmented.
The walls are also segmentend
How can I convert the segments to a single wall?
Merge walls wont work unfortunately
When I try to insert doors or windows the segments are too small, so a door or window will stick out at the side. Im trying to get this to function the same way as when you would have created the walls with the standard tool using round shapes.
10 REPLIES 10
Just FYI,
You may also try to model each of these long meandering Walls using the Polygonal geometry method, instead of modeling it using a series of curved and straight Walls. The advantage of this method is that each meandering Wall is a single element and you can still place Doors and Windows into it.
