Warning: Polygon is degenerated. at 1120 of file m_RailPost
Warning: Polygon is degenerated. at 1120 of file m_RailPost with Balusters.gsm.
HELP! PLEASE.
This happens when I try to open in 3D, Only when I try to see anything to do with the first floor of my drawing. If I just veiw the other lfoors, it seems to be fine.........
1 Reply 1
Aussie John
Without knowing the object, you probably have a parameter in the object which is causing it to create a bogie number. For instance if you have a door frame that is thicker than the door opening the object will try to to something impossible. The object often stops this but not always.
If there are more than one instance of the object, track it down by selectively choosing them. If it is not obvious which parameter is causing the problem it may be quicker to place a default version of it and reset as needed.
Cheers John
[/size]
