‎2004-07-16 11:17 PM
‎2004-07-20 07:24 PM
‎2004-07-20 10:11 PM
‎2004-07-21 03:19 PM
‎2004-07-21 05:17 PM
‎2004-07-21 05:31 PM
‎2004-07-21 07:31 PM
‎2004-07-23 07:35 PM
laszlonagy wrote:Laszlo,
I have found previously that such messages can appear while you edit the Object but it still works when saved and placed in ArchiCAD.
It happened to me with Zones.
What I found is when you are editing it, a lot of variables are not filled with real values that can occur only after actually placing the object.
If the variable is not filled up with a value, ArchiCAD assumes it is a numeric type (unless it is a parameter, which has its type defined). When it encounters a line that expects a string type variable it gives an error, since the variable is not filled up with a value yet (so it thinks it is zero, which is numeric).
