Kikoria
Weird 3D View in Archicad
Hello there. Have you ever had this situation in ARCHICAD 25 or 26? When you go to 3D view, there's a very strange display. The surfaces are strange and also the ridges are weird looking:
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
1 Solution
aarkell
Is your model very far away from the origin? That's the only time I've ever had the reference lines offset like that. If so, is it possible to move your entire model closer to the origin (0,0) in model space? Graphisoft generally recommends modeling as close to origin as possible, as it's a known issue that being very far away from it can cause glitches.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Go to post
2 Replies 2
aarkell
Andrew Arkell
AC 18-27 USA 5030
Kikoria
Wow, that was the case. thank you!
Kind regards,
Tamaz Kikoria
Architect
