Weird issue with overhead lines on empty opening
I've placed an empty opening in a wall, and set the empty opening as "projected with overhead". Overhead lines appear in the opening as expected. The wall Floor Plan Display is also set to "projected with overhead"
As soon as I make the empty opening smaller or bigger, the overhead lines disappear.
Is this a bug?
Daniel Kovacs
Graphisoft Alumni
I gave it a quick try, but I can't reach the same situation as you (with the overhead lines). It either shows me the projected parts, or nothing (unless I turn on the wall edge lines in the door settings, but then those are static lines, not overhead types).
I only got the overhead lines, when I used a complex profile wall, but then it stayed right there for me.
Can you send me a sample file and maybe a video? I want to reproduce this myself, to see if this is a bug.
Thanks.
Daniel Alexander Kovacs
GRAPHISOFT
It seemed to resolve by itself....not sure what I did!
Thanks anyway
