Weird wall connection problem
Hi all, I'd like a suggestion on how to make a proper connection between two walls with different core materials.
I've attached a screenshot of my problem, in essence I've tried everything but I can't get walls to connect in a realistic way if they collide at a a big angle (more than 135 degree usually), ideally I'd like the walls to connect at the red line that I drew.
Thanks!
1 Reply 1
Daniel Kovacs
Yeah, that happens because the skins are always run to the side of another skin, they don't connect to each other "frontally". Most of the times this gives the best result and this makes the most sense, but in other occasions (like this) it doesn't work out.
The solution I usually give in these cases (when you need walls to meet in a special/unusual way) is to use a complex profile column. Just draw the connection manually, and pace it as a column. Don't connect the walls to each other, they should both stop at the edge of the column.
Btw, a tip for complex profiles: use the hotspot tool to place hotspots in it on corners. This will create actual hotspots when placed, so you will be able to snap to them.
I hope this helps. Let me know if it didn't work out!
Regards, Daniel
Daniel Alexander Kovacs
GRAPHISOFT
