2009-04-03 04:46 PM
2009-07-01 06:06 PM
gpowless wrote:This makes no sense. Why would Graphisoft ever want that? The 2 programs don't even speak the same language.
I would take it further.
Archicad should directly read and write in Revit format instead of its own proprietary format.
gpowless wrote:There isn't really an enormity of a suggestion here, rather than an impossibility. Aside from the fact that CAD and BIM are 2 completely different (though not entirely unrelated) things, you still seem to fail to realize that since the Revit RvT file format is a CLOSED format, Graphisoft simply cannot make ArchiCAD capable of reading and writing in Revit's native format (even if they understand how Rvt files work) without an express agreement or understanding from Autodesk themselves, or without Autodesk themselves actually writing the translator for Graphisoft (like happened when GS and Google/@Last collaborated on a SKP-PLN addon translator for ArchiCAD).
I understand the enormity of this suggestion, but Graphisoft is competing head to head with Revit for the same user base. ....................
CAD should be no different.
2009-07-01 07:21 PM
2009-07-06 07:18 PM
2009-07-16 08:00 PM
2009-07-16 10:59 PM
2009-07-16 11:06 PM
2009-07-16 11:08 PM
2009-07-17 12:29 AM
owen wrote:Very true.
true .. but there is a big difference between 'can do it in ArchiCAD' and 'can do it in ArchiCADeasily'
it is one hell of a difference really. In Revit the process seems quite parametric - change the original surface and the associated elements adjust to match. Not so with ArchiCAD, i can imagine adjusting those things manually would be 'smash head through screen' stuff
2009-07-17 12:53 AM
Peter wrote:This is exactly what makes me pessimistic. The curtain wall tool has that unpleasant combination of being both substantially dissimilar to other hard-to-use, counterintuitive tools in ArchiCAD and yet it itself still being counterintuitive and hard to use.
We are only just beginning to see the start of a similar idea in ArchiCAD with the introduction of the curtainwall tool in AC12.
2009-07-17 01:17 AM
