What is on layer XXXX
I am trying to clean up our template. The Attribute Manager tells me there are objects on a certain layer, is there a way that I can find out what?
Thanks!
10 REPLIES 10
Dwight
You mean, some sort of list, without using the 'Find and Select' dialog to select all elements on that layer, then 'Zoom to selected'?
Dwight Atkinson
1. Edit/Find&Select... (Type is: 3D element; Layer is: AAAA); clic on "+" and all objects on that Layer are highlighted
2. Creating a Schedule:
And the Schedule settings:
Schedules only show 3D elements. (The other way to see 3D elements is to just go to the 3D window with only layer XXXX on.)
Unfortunately, there is no easy way to find the 2D elements on layer XXXX. While you can use Find & Select - or again, simply turn off everything except layer XXXX ... you must open EVERY SINGLE view ... every story, every worksheet, every detail, every section, every elevation, every layout, etc.... one by one and do a select all / zoom extent / or something similar to find the 2D elements.
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
David Maudlin
Dozi64:
In addition to the other advice, be aware that the Attribute Manager will show a layer as being used (check mark) if a Tool is assigned that layer as its default layer. (Open a new blank file and then look at Attribute Manager.)
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
That's what I was afraid of. Thanks for all of the replies.
Stress Co_
I renew my wish for F & S on steroids:
Find & Select Wish
It must be possible, yes?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Bruce
Use Document > Layers > Layer Extras > Active Layer to set all tool default layers to one layer. This makes it a bit easier to run the layer purge.
Also, you don't have to visit every view - just every project map entry (on large projects, this is prohibitive).
My wish list for this is to do what SketchUp does - give the user an option to transfer any object on the layer you are trying to delete onto a different layer. Easy.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Correct. I meant viewpoint.
