2016-06-08 04:58 AM - last edited on 2023-05-24 12:42 PM by Rubia Torres
2016-06-09 12:41 PM
2016-06-09 05:57 PM
Erwin wrote:Thanks for the detailed explanation, Erwin. In this case, I used a pretty clean AC19 file (from the GS AC19 residential template), and the walls did not have any surface textures assigned. I had changed the uncut outline from purple to black, thinking that this was the issue. After a significant time of working with purple walls in the 3D view, all of a sudden the walls turned to black. (I quickly applied some surfaces, of course.) That is why I am thinking the effect doesn't relate to missing textures, but rather an updating issue.
Did you try to merge the surfaces with the new ArchiCAD 19 template? <snip>
2016-06-10 08:58 AM
2016-06-16 12:34 AM
Richard wrote:It is coming from missing material of a wall (in your case, but can be any object, really). It does not have to do with transfer from AC17 to AC19. Same thing happens in all ARCHICAD versions without any transfer.
I am drawing an existing house, and cannot figure out where this purple color is coming from.
2016-06-16 05:42 AM
Anton wrote:Actually, no. It was caused by accidentally having overrides in the surface materials which were set to GENERAL. I found out that in such a case, ArchiCAD will use the color of the Uncut Outline Pen to color things. (I'm not sure how far this behavior goes back.) Setting the surface to any material but GENERAL, or turning off the surface overrides altogether (therefore using the building material), fixed things.Richard wrote:It is coming from missing material of a wall (in your case, but can be any object, really). It does not have to do with transfer from AC17 to AC19. Same thing happens in all ARCHICAD versions without any transfer.
2016-06-16 10:47 AM
Richard wrote:You will see this behavior a lot, so I would like to give a bit of explanation.
2016-06-16 11:54 AM
Anton wrote:It is the default surface material for when no other material is applied.
I can't recall any of the Surface materials called "GENERAL" in any of the out-of-the-box templates in any of the localized versions.
2016-06-16 01:15 PM
Barry wrote:Thank you, Barry.
2016-06-16 06:16 PM
Barry wrote:Barry,Anton wrote:It is the default surface material for when no other material is applied.
It has the index number '0'.
It is the very first material in your material list.
I think as mentioned before when used on a wall surface the 'general' material adopts the uncut line pen colour of the wall (see image).
2016-08-02 09:16 PM
