Why Doesn’t the Door Move Up When I Copy the Wall Upwards?
mrsneuna
When I copy a wall upwards in Archicad, the wall is duplicated correctly, but the door placed in that wall doesn’t move up with it — it stays in the original position. Why is this happening, and how can I make the door move together with the wall when copying?
Check the anchor position of the door.
If it is anchored to the storey, the door/window will not move.
If it is anchored to the wall base or wall top, then it will move with the wall.
4 REPLIES 4
Aaron Bourgoin
Check the Anchor point of the door/window. Link it to the wall, not the story.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Lingwisyer
Guru
Thinking about it, a good wish to make would probably be for the Anchor storey to change when you change the Host Home Storey.
thank you so much ❤️
Setup info provided by author
