Why can't I see/select separator lines in my composites?
Stress Co_
How do I get separator lines to appear and be selectable in section views?
I can see it when the composite is selected. But no "light mercedes" icon when hovering over it.
See attached.
Marc Corney, Architect
Red Canoe Architecture, P. A.
6 REPLIES 6
Its the same material, to get around this problem I have duplicates of the same material.
e.g Paint - Tea - 00 & Paint - Tea - 01
Stress Co_
Thanks Danj.
That was it.
I had tried using a duplicate Building Material,
But It didn't work until I changed the Material's Fill.
James B
In AC17, cut fills do not merge within the same Composite. I just double checked. Does the same thing occur in Floor Plan or 3D Document with this roof? Do you have legacy intersection method on or off?
James Badcock
Graphisoft Senior Product Manager
Stress Co_
I'm not sure how you mean in the Floor Plan view, but yes in a 3D Doc. the separator lines do not appear (they do now after altering the material's fills).
I've got legacy intersection ON.
I see how the separator lines appear when it's OFF.
James B
Floor Plan I only meant if the lines appear between the same building material.
With legacy on, it will behave as per AC16 (mostly), so with legacy off we improved the appearance of cut lines on composites/profiles in all views to be more consistent. But this is only a feature of AC17 with the legacy checkbox off.
James Badcock
Stress Co_
OK, got it.
I'm slowly transitioning to full AC 17 functionality (i.e. Building Materials) and as this project started in AC16,… I'm keeping legacy on.
Thank you James.
