Why some of my saved favorites are "grayed"?
I saved some favorites from my floor plan of a hotlinked module, but when I wanted to use them, they appera grayed in the favorite list, any guess what is wrong?
Thanks!
12 Replies 12
Link
Do they require library parts that you have not loaded?
Where n Mexico are you, Mario?
Link.
Hi Link,
The library parts are loaded, any sugestion?
by the way, I am located in Guadalajara, Mexico, have you been here?
If the favourites were created in a previous version, you need to load the library of the same version
HTH
They were all created in the same version AC12 and they are mostly doors and windows
Link
I don't recall seeing this for anything else apart from a part that is not loaded. Would you mind showing us your Window>Palettes>Library Loading Report, with any lists expanded?
Link.
Sure, here it is,
thanks
Link
Yep, it's as blank as a whiteboard in an Autodesk 'Integrity in Sales and Marketing' meeting.
So what is the chance of you creating these greyed out favorites in a separate project where a different library was loaded?
Check your PM.
Link.
Thanks Link,
I think what I'm going to do is to re-do them, fortunately they're a few and not so many, thanks anyway,
Djordje
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
