Window Label Issue
Chris Grantham
I am trying to use labels to tag my windows rather then than the marker option that is available within the window settings. I am doing this because I can't seem to get marker to show up as a hexagon, and it seems to work nicely for tagging in elevations. I have one particurley pesky label that does not want to rotate to be in line with the other tags. Whenever I try to rotate the label to match the others it defaults to being upside down or reading from the right as I have shown in the two images. Does anyone have any ideas? Thanks in advance!
-Chris
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
11 REPLIES 11
Erika Epstein
You can use James Murray's Shape Label. Its in the GDL object depositoryon the main page of Architalk posted by David Pacifico
Shape Label JM9
Put it in one of your libraries. When you have your section/elevation open, label the windows and doors as discussed above. Choose this Shape Label JM9 and all will be well again.
GO JAMES MURRAY for making such a great label
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Chris Grantham
Wow! Thanks for pointing that out Erika! This is an awesome label, I am done with the default archiCAD labels.
Mac OS 12.2.1
