Window, Mullions, Curved Wall
I need to make a full arch window that is 12" wide by 48" tall. It's built into a wall with a 3'-0" radius. The building itself is a full circle with the 3'-0" radius. I need the window's mullions to be at 45deg and 135deg, and the window has 2" trim all the way around it. Anyway to accomplish all this?
I made a custom window with the grids, but a custom window doesn't provide the trim needed. The trim itself has to curve in elevation and plan - impossible in archicad?
Thanks in advance for any tips.
11 REPLIES 11
SCSCadMan,
How did you make your "custom" window ?
Does your "custom" window have an arch-head frame
and is also curved in plan ?
Thank you,
Peter Devlin
I made the window in plan, then saved is as a GDL window. When a window is inserted into a curved wall, Archicad curves the window for you. Unfortunately, this method doesn't automatically include a trim option with the window.
SCSCadMan,
If you made the frame, sash, muntons, and glass in the 2D window
(using slabs I assume), then why can't you make the trim the same way ?
Please forgive my puzzlement.
Thank you,
Peter Devlin
Archicad automatically makes a window curved when it's inserted into a curved wall. Archicad DOES NOT automatically curve a GDL trim object. In archicad itself without GDL, it seems to be impossible to make an object that curves in plan and elevation at the same time!
Thus making trim go around the arch of the window (curved in elevation) and following the curve of the wall (curved in plan) seems to be impossible in Archicad.
SCSCadMan,
I am sorry that I can't help you with your issue,
but perhaps you could help me.
You say:
"Archicad automatically makes a window curved when it's inserted into a curved wall"
I am unable to make this happen.
If I make a curved wall in the plan, select a casement window, and
insert it into the curved wall, the frame, sash, and glass remain straight.
I see no setting that makes the window follow the curve of the wall.
How do you make this happen ?
Thank you,
Peter Devlin
I'm attaching a photo (hopefully, it will show up) that shows what elements appear curved. Most times in construction, a series of small-width straight windows are used in a curved wall instead of using curved windows.
undefined
SCSCadMan,
It appears from your photo that, in the plan view, all of the window
elements are straight not curved.
In the 3D view, all window elements are straight.
The only element that is curved is the sub-sill.
Are these statements correct ?
Is this sub-sill element part of the window object ?
If the above statements are true then in what way does
when it's inserted into a curved wall" ?
Thank you,
Peter Devlin
Peter wrote:
...If the above statements are true then in what way does
when it's inserted into a curved wall" ?...
I'm not so sure that ArchiCAD automatically curves anything...I might be wrong though. I would think that all of the prisms that make up the window and its trim components would need to be scripted using "BPRISM_"
Dan K
Dan,
I agree, they have to be BPRISMS with a radius derived from R_.
But SCSCadMan says quote :
As far as I can tell this is not true and if you need a curved window
you have to use GDL to make it.
Peter Devlin
