2014-01-20
06:18 PM
2023-05-24
09:04 AM
Rubia Torres
2014-01-20 06:33 PM
2014-01-20 06:36 PM
2014-01-20 07:09 PM
2014-01-20 07:29 PM
2014-01-20 07:34 PM
2014-01-20 07:39 PM
2014-01-20 08:20 PM
Felipe wrote:Usually this means that you are missing a step somewhere. Check your Building materials.
No, I unchecked that thing.. and the same issue appears in a brand new AC17 file with AC17 library... kind of weird that nobody else seems to have this issue
2014-01-20 09:34 PM
ejrolon wrote:I checked it, the window frame material has a higher priority than the slab's finish material... also, I noticed that when I edit the composite slab, if I set the finish material as CORE instead of FINISH, the problem is solved in the section, but looks bad in 3D...if it's set as FINISH, it looks bad on the section but looks ok in the 3D...Felipe wrote:Usually this means that you are missing a step somewhere. Check your Building materials.
