Window display problem
In the attached picture, why Archicad is not displaying the right corner of the window as in the left side.
5 Replies 5
Nobody is replying.
Seems like there is no solution for it in Archicad
Eduardo Rolon
There are a couple of posible reasons:
1. Check that in the window you don't have ganging on
2. Check that the wall were the window is placed is as long as he window
3. Select wall and use the "send backward" command until the line appears
4. Check that you don't have a wall in a hidden layer in the same spot
5. Check that you don't have multiple walls placed in the same spot
6. Check that you don't have a wall either above or below that is interfering.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Tried all your options, except second one, in vain. Could you please elaborate the second option ?
Eduardo Rolon
The second option is that the wall were the window is placed does not meet the perpendicular wall were the problem is.
BTW I tried to create the problem in AC20 and I am unable to duplicate at this time. Check that the version that you are using is up to date
AC29 US/INT -> AC08
I was using the option of Display order>sending to backward on wall, but it worked with bring to front. Thanks everyone for taking your time to help me.
