Window or opening in morph
Is there a way to create a window or an opening in a morph? If so, how is it done?
Thankss.. looking forward to your replies!!
David Maudlin
Hiba:
You can create openings (not place Windows) into Morphs, in the Help files see: Virtual Building > Construction Elements > Morphs > Basic Morph Editing > Push-Pull. Pushing a shape through the Morph to the opposite face will create a hole.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you David.
Well I understand how it's done, but for some reason, the push-pull command doesn't appear in my pet pallete..
Thanks for the advice, I'll do the signature now.
David Maudlin
Hiba:
You might find your issue in this thread:
Morph pet palette
