2025-06-04 03:04 PM - edited 2025-06-05 07:41 AM
Hey,
Going to post a picture below. Is there a good way to create that kind of window and door combination using window tools only and make those two separate objects. I know there is a door tool that makes this, but I need those separate for a schedule.
The problem that I am having is I need to put casing around them, but I cannot make a correct connection with casing in the middle.
I can maybe throw something together using morphs or columns and model this door casing in the middle with a separate object, but is there maybe a better way?
Operating system used: Windows 4100
Solved! Go to Solution.
2025-06-05 08:19 AM
Sorry you said you already new this.
Yes it will be one object.
As 2 separate objects, you could try the ganging options.
If the casing is still no good, you may have to model that separately.
I would go with the single door with sidelight personally.
2025-06-04 03:56 PM
There is no image in your post.
2025-06-05 07:42 AM
Yep. Forgot to add. Thanks for pointing that out.
2025-06-05 08:17 AM
You should be able to do that with the standard hinged door with sidelight.
2025-06-05 08:19 AM
2025-06-05 08:55 AM
Ganging will only do a full side, so you would be missing the surround on the lower portion of the door that abuts the window.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2025-06-09 07:32 AM
Thanks.
I thought there might be a better way to do this, but I guess not with stock objects. So I went with ganging and did them separate. Fortunately I have a balcony in front of the windows, so it hides missing siding on the lower part of the door as Lingwisyer sayed.
2025-06-09 08:08 AM
Do you not have the "Door with Sidelight on Side 1" object in your library? There should be a US version as well.
2025-06-09 08:13 AM
Yes I do have it. Reason why I do not want to use it is because I want to have a door and a widow separate in opening schedule.
