Windows XP or Vista
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-09-01
10:04 PM
‎2023-05-26
02:54 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-02 01:29 PM
As far as AC on Vista goes the pdf-ing was not working, maybe it's got fixed already.
You will be better off with XP that's for sure...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-03 01:41 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-04 07:30 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-04 07:39 PM
Perhaps you could let me know where the permissions are located? Didn't know there was such a thing....unless it's a teamwork thing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-05 12:28 AM
I had issues with the NZ bracing tools wanting to write to the file but vista not allowing it, this was fixed when I set archicad to run as administrator.
The problem when you run archicad as admin under vista is that you then get all these annoying windows that pop up asking if you are sure you want to do this.
To get around this problem I downloaded a program called TweakUAC which allow you to put User Account Controls into "quiet mode"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-10 02:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-10 06:31 PM
Was experimenting with everything on the Vista laptop and V11 because of freezing up problem.....discovered that if one right clicks on the desktop, then properties, then changed color qualities to 16 bit, it seems to fix the problem.
Seems to run fine, right now anyway. Don't know if this is a symptom of a graphics card problem or what, the card on the laptop is not listed in the compatability chart. No downloadable test for V11, so can't test the card.
Hope this will help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-10 06:41 PM
I am on my laptop as well, I will give tihs a try.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-09-16 12:07 PM
AC does not seem to multi task very well under either platform though, even when plenty of free RAM & CPU time available on dual core PC - switching back from another large pp, or after PC has been in standby mode, performance nosedives to unusable levels under either for me.
Perhaps MAC is better?
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
