Openings do not have layers, but respond to the layer settings of the wall with which they are associated. When working with existing construction, you typically need at least 3 wall layers: A-Wall (for new construction), A-Wall.DEMO (for existing to be removed) and A-Wall.EXST (for existing to remain), and 2 layer combinations: Demolition Plan = A-Wall.EXST + A-Wall.DEMO, and Construction Plan = A-Wall.EXST + A-Wall
If you are replacing windows within existing openings, or inserting windows in an existing wall, it's a little tricky, but can be done: 1) Insert empty openings in a wall (on A-Wall.EXST) to create the [existing] openings. 2) Fill these openings with walls (A-Wall.DEMO) the same size as the openings. 3) Copy these walls onto the A-Wall layer, and insert the new windows in these walls. 4) Insert any existing-to-be-removed windows in the A-Wall.DEMO walls of step 2.
