Karol Argasinski
Windows out of the wall
Dear All,
I encountered several problems with Windows, one of them is that windows, whatever you do, is out of the wall in 3D. In 2D view, representation is okay, while in 3D view it is completely unrelated. Do you guys know, how to solve it?
Best,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27/28/29 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
2 Replies 2
Hello Karol,
Do you check your display of structures ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Is it a complex profile wall?
If so you can try setting the position of the opening reference line in the profile settings.
There is a bug when a complex profile wall is used.
The 2D symbolic display of the window does not necessarily match the actual 3D position of the window.
Change the window to 'Projected with Overhead' and you will probably see it is in the wrong position in plan as well.
I could be on a complete tangent here though and may be confusing the issue even more.
Here is one post illustrating the problem.
I am sure there are others and I have reported it as a problem.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=62812
