Windows won't show in Layout
When I drag the elevation from VIEW to LAYOUT, the windows disappear and theres only a wall hole where the windows are suposted to show. Is there something I need to change in window settings to make them appear on my Layout?
1 Reply 1
Guru
My guess is that this is due to your object display settings. At the scale you are inserting the view at, the windows are set to display as "simple". You can change how objects interact with the view scale under their Window Settings & Options settings. I think by default this is linked to your Model View Options. In this case, on top of being scale dependant, windows and doors will not be displayed if it is set to Site or RCP.
Ling.
